PPPoE issue - Flint AX1800
Hi all,
Will like to check what is the issue of this?
Basic info: My ISP required to have 500 vlan for internet connection and 600 for iptv. I somehow managed to create the vlan through LuCi, however today perform a restart face this issue again, it was facing the same error initially when I setup Flint AX1800.
Below are the logs:
Fri Dec 17 09:10:08 2021 daemon.warn pppd[18757]: Timeout waiting for PADO packets
Fri Dec 17 09:10:08 2021 daemon.err pppd[18757]: Unable to complete PPPoE Discovery
Fri Dec 17 09:10:08 2021 daemon.info pppd[18757]: Exit.
Fri Dec 17 09:10:08 2021 daemon.notice netifd: Interface 'wan' is now down
Fri Dec 17 09:10:08 2021 daemon.notice netifd: Interface 'wan' is setting up now
Fri Dec 17 09:10:08 2021 daemon.info pppd[21444]: Plugin rp-pppoe.so loaded.
Fri Dec 17 09:10:08 2021 daemon.info pppd[21444]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Fri Dec 17 09:10:08 2021 daemon.notice pppd[21444]: pppd 2.4.7 started by root, uid 0
Fri Dec 17 09:10:23 2021 daemon.warn pppd[21444]: Timeout waiting for PADO packets
Fri Dec 17 09:10:23 2021 daemon.err pppd[21444]: Unable to complete PPPoE Discovery
Fri Dec 17 09:10:23 2021 daemon.info pppd[21444]: Exit.
Fri Dec 17 09:10:23 2021 daemon.notice netifd: Interface 'wan' is now down
Fri Dec 17 09:10:23 2021 daemon.notice netifd: Interface 'wan' is setting up now
Fri Dec 17 09:10:24 2021 daemon.info pppd[22745]: Plugin rp-pppoe.so loaded.
Fri Dec 17 09:10:24 2021 daemon.info pppd[22745]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Fri Dec 17 09:10:24 2021 daemon.notice pppd[22745]: pppd 2.4.7 started by root, uid 0
Thank you for help.
Hi, I’m not sure luci can handle setuping up vlan interace on flint.
You better edit /etc/config/network, internet connection interface should be like this,
config interface ‘wan’
option hostname ‘GL-AX1800-d40’
option metric ‘10’
option proto ‘pppoe’
option username ‘[email protected]’
option password ‘my_isp_password’
option disabled ‘0’
option ifname ‘eth0.500’
option ipv6 ‘0’
Could you tell what your setting of iptv interface?
Btw, “Timeout waiting for PADO packets” is more like link layer problem, you can try restart modem also.
Yes, you can setuping up vlan interface on flint
Luci → Network → Interfaces → Wan → Edit → Physical Settings → Custom Interface: eth0.500
It works for me
I tried restart router and it works again, I am not sure what is the issue that causing this. Same error too.
This is my current setup.
Do you have a configuration backup( at luci http://192.168.8.1/cgi-bin/luci/admin/system/flashops) when it works, and check the difference when It doesn’t work.
