Hello, i find a little bug, when you set PPPoE Setting and save it and then change Ethernet Settings to DHCP, PPPoE Setting is reset from your provider setting that you set to clean. That’s annoying. Pl’s fix it.
Ax1800 fw Version 4.3.2
Thanks, will check it.
