I realize that the VPN has been designed to prevent any IP leaks.
If I wanted to take this one step further and add a “double kill switch” for a particular client IP, i.e. one that is statically assigned, what would be the best method to do this?
Is there a certain iptables rule that should be used in the startup firewall script? Even if VPN is “stopped” I would not want certain hosts to reach the internet. They’d all have static IP.
Do you have a recommended VPN policy to use or would you be able to walk me through the steps? I do have a linux background but am generally a novice at these types of endeavours. I realise it’s probably easy, so any help you could provide would be welcomed.
