Is it possible to use Private Internet Access vpn on a Slate GL-AR750s-EXT with Wireguard?
Would someone be kind enough to point me to a tutorial?
According to the the website, PIA is supported with Wireguard.
Thanks!
Thanks!
I do not have Private Internet Access, but I seem to remember a post on this forum that PIA does not provide WireGuard config files. If so, the GL.iNet app is the best method.
There may be a tool to generate PIA WireGuard config files yourself, on a system running one of the PIA apps.
There is a video guide here.
there a script to generate pia wg config. You can extract the api calls and generate your own config on the fly
and also pia own script
The IOS app made it extremely simple. Thank you!
I created my own script that i use on my GLiNet routers i use private internet access with private dedicated ip and it works fine.
Hopefully it helps those who need their wireguard config files from pia.
