Problem setting up VPN on Beryle AX with NordVPN
I already update the firmware to the latest. This is the first time to setup the new Beryl AX router with NordVPN client. I am getting this error in the log:
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Rule ‘process_mark’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Rule ‘wan_in_conn_mark’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Rule ‘lan_in_conn_mark_restore’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Rule ‘out_conn_mark_restore’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Zone ‘lan’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Zone ‘wan’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Zone ‘guest’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Zone ‘ovpnclient’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Set tcp_ecn to off\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Set tcp_syncookies to on\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Set tcp_window_scaling to on\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Running script ‘/etc/firewall.nat6’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Running script ‘/etc/firewall.vpn_server_policy.sh’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Running script ‘/var/etc/gls2s.include’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): ! Skipping due to path error: No such file or directory\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): * Running script ‘/usr/bin/gl_block.sh’\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): Failed to parse json data: unexpected character\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): uci: Entry not found\n
Sat Jan 6 12:10:33 2024 daemon.notice netifd: ovpnclient (2909): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory\n
Afaik these log lines are normal, none of them indicate an issue.
Do you have an issue?
There is “failed to parse json data” and “no such file or directory” error.
There are more errors after the above.
The VPN client keeps trying for over 5 minutes, and never success. Yellow light always on.
Yeah, but those lines are normal.
Are you sure you entered the right credentials? There a specific ones for NordVPN - it’s not just your login.
You can view them in the NordVPN control panel.
Where do I enter another login, other than the login screen?
I am already logged on and got a list of VPN servers from NordVPN, and there is no authentication error.
sat jan 6 12:40:06 2024 daemon.warn ovpnclient[23311]: WARNING: --ping should normally be used with --ping-restart or --ping-exit\n
sat jan 6 12:40:06 2024 daemon.warn ovpnclient[23311]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: Outgoing Control Channel Authentication: Using 512 bit message hash ‘SHA512’ for HMAC authentication\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: Incoming Control Channel Authentication: Using 512 bit message hash ‘SHA512’ for HMAC authentication\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.153.179.110:1194\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: Socket Buffers: R=[212992->212992] S=[212992->212992]\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: UDP link local: (not bound)\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: UDP link remote: [AF_INET]185.153.179.110:1194\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: TLS: Initial packet from [AF_INET]185.153.179.110:1194, sid=a61ebfcb 33b24723\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA8\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY KU OK\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: Validating certificate extended key usage\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY EKU OK\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY X509NAME OK: CN=ca1571.nordvpn.com\n
sat jan 6 12:40:06 2024 daemon.notice ovpnclient[23311]: VERIFY OK: depth=0, CN=ca1571.nordvpn.com\n
sat jan 6 12:40:07 2024 daemon.notice ovpnclient[23311]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512\n
sat jan 6 12:40:07 2024 daemon.notice ovpnclient[23311]: [] Peer Connection Initiated with [AF_INET]185.153.179.110:1194\n
sat jan 6 12:40:08 2024 daemon.notice ovpnclient[23311]: SENT CONTROL []: ‘PUSH_REQUEST’ (status=1)\n
I guess you are successfully connected now ?
No, still showing “The client is starting, please wait…”
The log is fine. The “failed to parse json data” is generally because no vpn policy is set up. Not a problem.
The reason that you cannot connect to Nord is generally that the server has problems or your network is blocking.
Oh I figured it out! I contacted NordVPN and they told me I have to use special token to connect instead of my NordVPN ID. It’s working as expected now! Thanks
:expressionless:
:smile:
Didn’t know that as a newbee, sorry :rofl:
Guess it’s NordVPN. Why don’t they show it in your dashboard like “HEY. LISTEN. YOU NEED THESE CREDENTIALS FOR LOGIN” - but yeah… guess why… it’s Nord.
But in that case, the log ususally show “Auth-failed”.
Not sure why is does not display.
Can you help me with a question? I am not getting any replies on my posts I have made & am in need of serious help. I am a newbie!
