I'm writing to you because I want to use a GL-MT300N-V2 (Mango) for my work.
I want to connect remotely using a VPN.
I followed the tutorial from this video :
I've connected several ways and I can't get a public IP address:
With an ethernet cable from the router -> to the Mango wlan port
Tethering with my Android smartphone
By repeater with my company's Wifi.
No matter how I connect to the Internet, I can't get a public IP address. When I go to Internet -> IP Address, I get a local IP (192.168.XXX.XXX). However, when I go to Application -> Dynamic DNS -> DDNS Test, I get this message: "The IP from DDNS domain resolution is not the same as the WAN IPs of the device. You need an Internet Public IP address to use the Dynamic DNS. If this router is behind NAT, you may need to set up port forward in your ISP router. If you have VPN Client enabled, please disabled "Services from GL.iNet Use VPN" in the global options ".
And just below I have a public IP address (IPv4) and a local one (Interface WAN IP).
I still tried to connect with Wireguard and/or OpenVPN. For Wireguard, it doesn't go any further than handshake and for OpenVPN, it doesn't work either...
Note that I successfully detect my Mango on GoodCloud and it does put my Public IP on (Same IP as the DDNS after scan).
Thank you for clarifying this problem for me.
Admin pannel v4.3.17
kernel version 5.10.176
Best regards
Kevin Jacot-D.
