Problem with sound and mic - nothing working
Hello
I have set up the Comet Pro and the KVM is working fine and accessible via the web. However, the sound is not coming through from the computer I am trying to remote into, neither is the mic. Both are essential for my use case. It is a Windows computer, and the machine I am accessing it with is a Mac. I’m not sure this matters much as it should simply be sound being transmitted via the KVM application.
I can confirm that the sound and mic options are enabled from within the application. I have tried selecting different options from the Windows machine but no success.
Please advise what my next steps should be.
Please follow this guide to troubleshoot: No audio from the controlled device - GL.iNet KVM Docs
Note that this permission needs to be granted to use the microphone.
This was related to the GLI app, not via browser.
I have fixed the issue. It will not work with VPN. Whilst my VPN was enabled, it did not allow audio of any kind, or access to my local computer’s clipboard. Also connecting to the machine did not work unless it was disabled initially. This might help someone in future - please check your VPN if you have one running whilst in a remote session.
This is definitely valuable information that could help other users who run into similar problems.
Appreciate you taking the time to let us know!
