Problem with the GL-AR300M16-ext router. Firmware Version 4.3.17. When connecting WireGuard Client via the built-in interface to
Mullvad, when I enter my 16-digit account and click "Save Credentials and Get Servers", an error appears: -7Get Mullvad Address Fail!
Please help me fix it!
Screenshot attached. Thanks in advance)
Does your internet work fine? Do you use AdGuard Home?
Internet works fine and I use AdGuard
Can you please check if the error occurs when you disable AGH as well?
When you disable AdGuard - the same error
When I disable AdGuard the same error occurs
Your Mullvad account is active and has still days left?
yes, active. Almost a whole month left)
Since you are located in a country where VPN is forbidden: This might be the issue.
Guess your gov is blocking the server to get the config files.
You might need to create them manually.
Some processes of the router are explicitly called without VPN. I could imagine that retrieving the Mullvad server is one of them.
@bruce Can you check?
Yes, I've already done this and that. Nothing helps(
Could there be a bug in the firmware itself? Has anyone accessed Mullvad through the internal interface?
Does your Mullvad VPN works if you enable it?
Sorry about that, I have reproduced this situation, will ask R&D guy to check.
Thank you! Will you write back based on the results of the check?
YES, Mullvad VPN works when I turn it on
I have check by my side, it works. Sometimes probably ISP network issue.
