i flashed the firmware 1.4 domino openwrt-ar300m-ubi-tor-1.4.img. the web-if say ethernet connected. tor connected. i tested the tor-connection with browser (safari) by torcheck xenobite.eu and this website say Your IP is NOT identified to be a Tor-EXIT. So you are NOT using Tor to reach the web!
Yes, the switch is on the left side. I tested: Your IP is NOT identified… and i can use des admin-webinterface. I tasted the right side: Your IP is NOT Identified to be a tor-exit and i can use the webinterface also. the status of tor is: CONNECTED.
@damain, sorry I cannot understand clearly. Seems you installed the Tor firmware from the stock firmware v2.25 now it doesn’t boot? Now you want to debrick using uboot?
Took more than 3 hours for me to understand the way the tor firmware working.
I get the firmware from this link: GL.iNet download center
Uploading and flashing no issue.
Default SSID = PORTAL with password = goodlife
With switch turn on to right side, we can access and edit using browser on UI page (default: 192.168.8.1)
Tor status connected on landing page after login.
but https://check.torproject.org/ showed “Sorry. You’re not using TOR.”
With switch turn on to left side, we can not access UI page on browser. I try SSH, connection reset by peer.
but https://check.torproject.org/ showed “Congratulations. This browser is configured to use Tor”.
My question: Is it the right way at this moment? Put the switch on the right side for configuring the router. Put on the left side for using tor, but no access for configuring the router.
