Problems on AdGuard Home after upgrade firmware on Brume2
Hi everyone,
I have a Brume2 and today I did the proposed upgrade to 4.7.4 Release 6 keeping the configuration. When I restart the device in the AdGuard Home Request Log I no longer see the client IPs but only the loopback address 127.0.0.1. The installed AdGuard Home version is 0.107.58. I tried to do the proposed upgrade to 0.107.60 but nothing changes, so I did the rollback via the admon procedure
Thanks
Is the others feature on MT2500 enabled?
ADG v0.107.52
MT2500 FW: v4.7.4 R6
I tested it locally and did not reproduce the issue that the clients list of ADG of MT2500 only shows 127.0.0.1, and all clients can display statistics normally.
The problem occurs with ADG 0.107.58 to 0.107.60 with firmware 4.7.4 R6. Now after resetting everything and installing the new version of ADG (0.107.61) it works regularly
Are you using the update script?
Hi, yes... I use the script for both upgrade and downgrade. For downgrade I follow the instructions in the Reverting paragraph.
