Problems using SSH terminal on Beryl AX GL-MT3000
https://youtu.be/luX37Itrp4s?si=e-nhGy60ZZmfTfiv&t=237 I am trying to follow this video to use SSH to change the 2.4GHz settings so I can see channel 14 but I am getting this error when trying to paste the commands they use into the terminal
In the video they say the command is different for other models. You have a MT3000
Please refer to this for a similar issue:
As you see for the MT3000 uses mt798111 for the 2.4 band and mt798112 for the 5G
Hmm how sure are you the path exists?
Depending on the firmware differences wether between op24 or mtk sdk, or the one from the video the path in the uci command might be wrong.
uci show wireless will give you a idea :+1:
I have the same router as the OP
The path exists
Try this:
#wifi 2.4ghz
uci set wireless.mt798111.country='JP'
uci set wireless.mt798111.region='5'
# wifi 5ghz
uci set wireless.mt798112.country='JP'
uci set wireless.mt798112.region='5'
uci commit wireless
# restart wifi for both bands
wifi
You might want to adjust the region, i never used that option before, likely it's very country specific :+1:
If I still can't see channel 14 what else should I do?
about which model router we talk about?
which firmware? Op24/MTK?
Beryl AX GL-MT3000 is the model I don't know about the firmware
