Hello all.
I have been tinkering around with flint 2 for a while now and for the life of me cannot get port forwarding to work.
I am on debian trixie and am by no means experienced in linux, networking or scripts, I put together this in an attempt to automate the process. Proton is as far as I know the only vpn left that supports port forwarding, but gives no control, they assign a random port number when a tunnel is created.
So my intent was to have a script that runs when i log in and handles the tedium for me
- detects what port has been assigned
- creates port forward rule within luci
- creates ufw rule
-ideally remove old ufw rules created by this process without touching any other rules i manually set
-gives a desktop pop up notification telling me which port is active
- pushes the active port to qbittorrent
#!/bin/bash
# Force right desktop screen for notif
export DISPLAY=:0
export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/$(id -u USER)/bus"
# --- CONFIGURATION ---
ROUTER_IP="ROUTER_UO"
DEBIAN_IP="DESKTOP_IP"
INTERFACE="wgclient2"
QBT_URL="http://localhost:8080"
QBT_USER="placeholder"
QBT_PASS="placeholder"
LAST_PORT=""
while true; do
PORT=""
# 1. ROUTE MANAGEMENT
ssh root@$ROUTER_IP "
ip route add 10.2.0.1 dev $INTERFACE scope link 2>/dev/null
ip route add 10.2.0.2 dev $INTERFACE scope link 2>/dev/null
# 2. PORT DETECTION
for GATEWAY in "10.2.0.1" "10.2.0.2"; do
OUT=$(ssh root@$ROUTER_IP "for i in 1 2 3; do RES=\$(natpmpc -a 1 0 udp 60 -g $GATEWAY 2>&1); if echo \"\$RES\" | grep -q \"public port\"; then echo \"\$RES\"; exit 0; fi; done")
PORT=$(echo "$OUT" | grep -oE "public port [0-9]+" | awk '{print $3}' | head -n 1)
if [ -n "$PORT" ]; then
SELECTED_GW=$GATEWAY
break
fi
done
# 3. Trigger update on port change
if [ -n "$PORT" ] && [ "$PORT" != "$LAST_PORT" ]; then
echo "$(date): New Port $PORT. Updating rules..."
# WIPE old rules with 'VPN-Sync' tag
while sudo ufw status numbered | grep -q 'VPN-Sync'; do
NUM=$(sudo ufw status numbered | grep 'VPN-Sync' | head -n 1 | awk -F"[][]" '{print $2}' | tr -d ' ')
sudo ufw --force delete "$NUM" >/dev/null 2>&1
done
# Add the fresh port rules IPv4, IPv6 disabled on router
sudo ufw allow proto tcp from any to any port "$PORT" comment 'VPN-Sync'
sudo ufw allow proto udp from any to any port "$PORT" comment 'VPN-Sync'
# 4. ROUTER/Luci UPDATE
ssh root@$ROUTER_IP << EOF
# Remove any previous manual rules to avoid ghost entries
uci -q delete firewall.ProtonForward
# Create a named redirect section LuCI can read
uci set firewall.ProtonForward=redirect
uci set firewall.ProtonForward.name="ProtonForward"
uci set firewall.ProtonForward.src="wan"
uci set firewall.ProtonForward.src_dport="$PORT"
uci set firewall.ProtonForward.dest="lan"
uci set firewall.ProtonForward.dest_ip="$DEBIAN_IP"
uci set firewall.ProtonForward.dest_port="$PORT"
uci set firewall.ProtonForward.proto="tcp udp"
uci set firewall.ProtonForward.target="DNAT"
uci set firewall.ProtonForward.enabled="1"
# For VPN forwarding: match the tunnel IP
uci set firewall.ProtonForward.src_ip="10.2.0.2"
uci commit firewall
/etc/init.d/firewall restart
EOF
# 5. QBITTORRENT UPDATE
COOKIE_FILE=$(mktemp)
curl -s -i -X POST -d "username=$QBT_USER&password=$QBT_PASS" "$QBT_URL/api/v2/auth/login" -c "$COOKIE_FILE" > /dev/null
curl -s -X POST -b "$COOKIE_FILE" -d "json={\"listen_port\": $PORT}" "$QBT_URL/api/v2/app/setPreferences"
rm -f "$COOKIE_FILE"
# 6. FIXED NOTIFICATION
if command -v notify-send >/dev/null; then
sudo -u USER DISPLAY=:0 DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/$(id -u USER)/bus notify-send "VPN Sync" "Port $PORT is now live."
fi
LAST_PORT="$PORT"
fi
sleep 45
done
Some of the pieces are static
Qbittorrent:
- bound to ethernet network interface
- bound to desktop ip
- pmp turned off
Router:
- VPN tunnel name
- Kill switch on
VPN:
- All configs have pmp enabled
- persistentkeepalive=25
- MTU 1380
- Allow remote access the LAN subnet on
- killswitch on
Now I am well are this is nothing impressive or even polished, but what’s confusing is that it works intermittently.
2 days ago worked fine, port was open and reachable upload speeds were great
Yesterday I had to run the script a few times when changing server but it all worked
Today, the script seems to have done everything, detected new port number, created port forward rule in luci, created ufw rule, pushed port to qbittorrent, but my upload speeds are 0 and any port check tool says the port is closed and I get issues like this indicating traffic being sent but problems lying elsewhere
14:17:27.508617 [.] ACK (Handshake Complete)
14:17:27.508680 [P.] Data Sent (68 bytes)
14:17:27.856602 [R.] Connection Reset by Peer
If anyone has the time to take a look and see where i'm going wrong or even just suggestions for things like the not yet working ufw redundant rule clearing part, i'll be happy to hear it, Thanks
