I managed to get my DHCP sorted thanx to awesome people here in the forums.
Now I need help with the vpn.
My protonmail only seems to download openvpn config files, but i need zip for wireguard.
Ya, managed to do it from my phone. Really cool actually. Say you downloaded 2 config files from pc, but your using your phone. There is a feature where you can choose config files between pc and phone. Naturally you can store these config files via phone and gain access to them from pc. Because it’s cloud based you can access any stored files and switch between these platforms
I will be looking into local storage via home assistant but for now this is a great feature to have. The other thing I would like to look into is tunnelling https://www.reddit.com/r/ProtonVPN/s/OtUlPD9oDB
I believe this has just been introduced but will help a lot because my TV is being affected by the VPN. Sure, I could have the VPN installed on the android TV and may need to choose exact VPN protocol but it’s troublesome and tunnelling is far more easier
Turns out Protonmail recently added Split Tunneling
This may come in handy should your Android TV not work correctly because your wireguard's VPN config file is addressed to all devices on your network
Method 1 - Android TV
Open protonmail app on your android tv and go to settings > split tunneling
Select Split tunneling > Select Mode > Select wireguard > and choose what apps you would like to be included or excluded from the VPN
Once done click reconnect and your android TV should not have any VPN assigned to it
Method 2 - Desktop or Laptop
Open Protonmail VPN
Hamburger menu > Settings > Advanced > scroll down to the bottom and select 'Split Tunneling'
Select 'Exclude apps/Ips from using VPN tunnel' and to the right side there will be an option to manually enter in your android tv's IP address. Enter this in and click on the + button
