Dear all.
I have proxmox homelab with wiregurde install on it and I creat client for my iPhone and one for GL-MT3000 Wi-Fi 6 Travel Router MEET Beryl AX
I can connect to my home server through my iPhone without any issue when I set up VPN on iPhone, but I with GL-MT3000 Wi-Fi 6 Travel Router MEET Beryl AX I get internet connection after upload VPN conf file, but I can’t connect to my home server.
Is there any missing set up to get connect to my home server?
with regards
You gotta tweak some routes/WG gateway(s):
thank you @bring.fringe18 for your reply I would like to mention that I already install wiregurde on proxmox homelab and I don’t want GL-MT3000 act as wiregurde server NO I want GL-MT3000 connect to wiregurde in my homelab
Can you ssh into the Beryl AX & post the output of wg show
after you’ve attempted to connect to your Homelab endpoint? I assume you’re using the same Internet connection as your iPhone but WAN thru a cable instead of Wi-Fi.
Comparing the conf in the iPhone against the one loaded into the Beryl AX is worth checking. There may be something, however unlikely, missing there… like persist_keepalive = 25
if I had to guess.
root@GL-MT3000:~# wg show
interface: wgclient
public key: ICQpBs7K3mOpK0An31fFKwxJm18hASWqlk16dXznYQY=
private key: (hidden)
listening port: 41245
fwmark: 0x80000
peer: QSL+WquCAQC1Qx2xBQ5ABNml/cJiXWyGFpQNeJ816Fk=
preshared key: (hidden)
endpoint: xxx.xxx.xxx.xxx:51820
allowed ips: 0.0.0.0/0, ::/0
latest handshake: 9 seconds ago
transfer: 28.45 KiB received, 20.76 KiB sent
persistent keepalive: every 25 seconds
any help please regarding configuration
The WG confs you posted look good. Can you ssh into the Beryl AX & post the output of Doing the same on your Promox server would be helpful if you can get into it fr your phone.wg show
Output from nslookup $yourDDNS
would be helpful.
You don’t always need to post screenshots. Text output fr the CLI or configuration files can be posted
like
this
like
this
