Proxmox + pfsense with Flint 2
Hi. I am interesting to make proxmox and pfsense.
I have new mini pc nuc with two entrnet ports. But I am really don’t know will be work with flint 2?
So plan wan to lan 1 mini pc (one cable). Lan 2 mini pc to wan flint 2. I should turn off dhcp in flint 2?
Thanks
Yeah you can put the device in AP mode from my understanding
You mean Flint 2 change mode router to Access Point? Does work adguard in flint 2?
I’m not sure if agh works in AP mode, but you can easily setup a agh container in proxmox and assign that IP to you pfsense DNS entry.
That would be the best method
Oh thanks, I did not know. What about wireguard? Same in proxmox?
You can, or run it in pfsense. I’ve ran it in PF but it was hard to set up
