Puli AX dual sim failover
I have a puli ax with two sims installed. I would like for the puli to use 30gb from the first sim and then switch to the second. Then at the end of the month I would like it to reset back to the first as the data usage gets reset every month. Any idea how to do this or where I should be looking in the settings for this?
No far we don't support such failover mechanism, according to the data usage.
I think we shall try to work it in the future.
Thanks @rain! I will look for it down the road. For now I will do the switch manually as I approach the data limit.
Hi, do you think that a failover using eSim could be possible? I mean change the different eSim profile inside the single sim Slot?
Sure, we shall add such profile failover in eSim in the future.
Thus you can choose a mount of profiles and run the failover over them.
