Puli AX (GL-XE3000) Input voltage
What is the input voltage range for the Puli AX (GL-XE3000)? I’m looking for an alternative power source (such as a USB-C to barrel plug adapter).
Thanks
On the assumption that the XE3000 takes the same voltage as the Spitz AX X3000 the input voltage range is 9-36V. I use this barrel plug with my X3000 in my RV. https://www.amazon.com/gp/product/B089K7LDMS There was a thread a while back on this very question but in regards to the X3000. You can find more information there.
For the USB-C idea it’s my understanding that you can combine a USB-C PD power brick and a special USB-C cable that request 12V and use that with the router.
Edit: Min voltage corrected to 9V. Credit to @RVer
Thanks for the reply. I saw that thread as well. Since this model has the built in battery (and charger) I didn’t know if that had any impact.
One small correction, for those of us who occasionally allow the RV batteries fall slightly below 12V: the X3000 supports 9-36V DC: GL-X3000 Spitz AX input voltage range - #2 by Tim-Zhang
I do agree that, for those using a USB-C PD adapter - definitely use a USB-C to 12V barrel adapter (5.5x2.1mm barrel plug).
Thanks for the voltage correction. I thought it may have been 9V min and had planned to confirm that and edit my post but totally forgot.
XE3000 has internal battery, and the battery has safety risk if leaving it in a high temperature environment. So XE3000 is not suggested to be used in RV.
XE3000 input voltage is 9~16V.
Hi Tim-Zhang, is it still correct max 16v? is it not possible to connect 24v ?
XE3000 only supports 12V DC-In(9~16V), can't connect to 24V.
I have a 4s battery so max voltage would be 16.8v (4.2*4), lowest would be around 12v, would 16.8v damage the EX3000?
Hi Tim, this might be an issue since the USB-C PD cable that we sell (which says it supports Puli AX) supposedly negotiates up to 20V. This sounds like a problem. Let’s discuss internally.
