What’s the battery uptime for GL-XE300? Specifications mention <4.4W power draw and a battery of 5000mAh.
I’m interested in 4G mainly (IoT gateway), so WiFi can be turned off when in battery but turned on when in AC.
I didn’t test. With wifi on it can work 6-8 hours. So without wifi it should work longer.
Do you think that by disabling WiFi, switching to 2G (not sure if that helps) and maybe using a bigger battery I can get it to work for a week?
My goal is to use it as a gateway for some devices, where I can remotely connect and/or fetch data.
How long does charging take?
2G network consumes more power than 3G and 4G.
Didn’t check carefully about changing time.
I had a Wyze cam that draws about 2 watts hooked up to a 12 volt deep cycle golf cart battery and if I remember correctly I got about two weeks out of it.
