APN is correct. Used the same profile before and gotten 30Mbps/6Mbps.
Channel 1 and 40 were used before in the same location. On both I had:
- ul_bandwidth 20M
- dl_bandwidth 20M
Now it is defaulting to band 5. After this
ul_bandwidth 5M
dl_bandwidth 5M
If I set the band to 1 or 40, I get much better speeds although now for both I get
- ul_bandwidth 10M
- dl_bandwidth 10M
As I understand this the downlink frequency or modulation in MHz? Is this something that can be managed? Because it might not be.
+QMBNCFG: "List",0,1,1,"ROW_Generic_3GPP",0x06010821,202307171
+QMBNCFG: "List",1,0,0,"Telstra-Commercial_VoLTE",0x06800118,202112171
+QMBNCFG: "List",2,0,0,"Volte_OpenMkt-Commercial-CMCC",0x06012064,202107271
+QMBNCFG: "List",3,0,0,"OpenMkt-Commercial-CU",0x06011510,202109061
+QMBNCFG: "List",4,0,0,"TW_Mobile-Commercial_VoLTE",0x06800201,201712042
+QMBNCFG: "List",5,0,0,"Commercial-DT-VOLTE",0x06011F25,202008051
+QMBNCFG: "List",6,0,0,"Commercial-KT",0x0601280D,202111231
+QMBNCFG: "List",7,0,0,"Commercial-Reliance",0x06011B34,201904021
It is working and I am getting more stable speeds now after the upgrade. Definitely a resolved issue for me. I did have to tinker around with the bands and reboot the router a couple of times for it to pick up a faster band.
Also I managed to get the original firmware EP06ELAR03A20M4G from Quectel forums, which at first sight looks and performs about the same. But I have kept using the firmware from this comment which seems to perform better and more stable
