u cant just change date on releases
Do you mean version 4.3.6? What specific problems are you experiencing?
It went through several rounds of testing, and definitely had more than just modified compile times. Perhaps you have a scenario that we didn’t test.
Hello
Unknown error occurred. Please check the network environment or reboot the device.
Rebooted a few times but still no working wifi but disable it now
And the the goodcloud app + puli is not working perfect nothing shows up , time zon is redmarket all the time but synkning says ok
2880.687621] br-lan: port 1(eth0) entered disabled state
[ 2880.736992] device eth0 entered promiscuous mode
[ 2880.786942] br-lan: port 2(wlan0) entered blocking state
[ 2880.792575] br-lan: port 2(wlan0) entered disabled state
[ 2880.883973] device wlan0 entered promiscuous mode
[ 2880.942256] br-lan: port 2(wlan0) entered blocking state
[ 2880.947796] br-lan: port 2(wlan0) entered forwarding state
[ 2880.953628] br-lan: port 1(eth0) entered blocking state
[ 2880.959062] br-lan: port 1(eth0) entered forwarding state
[ 2988.944221] device wlan0 left promiscuous mode
[ 2988.949051] br-lan: port 2(wlan0) entered disabled state.
