I use a few different VPN servers (as some things like Prime UK only work on Nord but I prefer Wireguard so don’t always use it).
What I’m wondering is how to set Nord DNS for OpenVPN without affecting the DNS at other times, so was hoping to push DNS settings via the .ovpn config file if that’s possible
Any tips on if it’s possible to define DNS on a per confg basis like this?
You must have set up Admin Panel → MORE SETTINGS → Custom DNS Server which overrides NordVPN using their own DNS servers by default.
I was going to suggest adding the “dhcp-option” line. You can add 2 separate lines for both NordVPN DNS servers (103.86.96.100,103.86.99.100) for redundancy.
