QCM v QMI protocol
What is the main difference between QCM and QMI protocols? Which one should I use for a 4g router
QMI is a standard protocol that various modem use.
QCM is for quectel modems. Supposed to be better compatible with Quectel modem but I have no more info.
Has anyone figured out what exactly it's for?
For me, it was always set to QMI. It worked everywhere. Now, in Belgium, it only works if I set it to 3G; otherwise, the router doesn't connect to the mobile network.
Interesting, because I just had the same experience when moving a router from the UK to Greece but I have no idea why this would be the case.
QCM is Quectel Connect Manager. My understanding is it is an abstraction layer above the underlying QMI connection
Connection modes:
⚫ QMI protocol
⚫ MBIM protocol
⚫ AT+QNETDEVCTL
