I can’t seem to be able to find documentation for configuring the QOS on the GL.iNet GL-MT3000.
That's because there's none to be found. You'll have to get into LuCI.
GL GUI -> System -> Advanced Settings .
Make a backup of your current settings, of course:
Where do I find QOS settings in:
GL GUI → System → Advanced Settings ?
please, I cannot find it no matter how many times I look through the advanced settings. (Luci).
You’ll have better luck over on the OpenWrt Forums; QOS isn’t supported by GL at this time which is why you need LuCI to install & configure it.
Backup
http://192.168.8.1/cgi-bin/luci/admin/system/flash -
Install package.
http://192.168.8.1/cgi-bin/luci/admin/system/opkg -
Enable SQM.
http://192.168.8.1/cgi-bin/luci/admin/network/sqm
In this case, for simplicity, I’ll be starting with SQM.
Installing luci-app-sqm (git-21.188.55209-f161b40) to root...
Downloading https://fw.gl-inet.com/releases/v21.02.3/packages-4.0/aarch64_cortex-a53/packages/luci-app-sqm_git-21.188.55209-f161b40_all.ipk
Installing kmod-sched-cake (5.4.211-1) to root...
Downloading https://fw.gl-inet.com/releases/v21.02.3/kmod-4.2.1/aarch64_cortex-a53/mediatek/mt7981/kmod-sched-cake_5.4.211-1_aarch64_cortex-a53.ipk
Installing sqm-scripts (1.5.1-1) to root...
Downloading https://fw.gl-inet.com/releases/v21.02.3/packages-4.0/aarch64_cortex-a53/packages/sqm-scripts_1.5.1-1_all.ipk
Configuring kmod-sched-cake.
Configuring sqm-scripts.
Configuring luci-app-sqm.
Updating database.
Database update completed.
Finally, apply.
The SQM GUI has just enabled the sqm initscript on your behalf. Remember to disable the sqm initscript manually under System Startup menu in case this change was not wished for.
Finally, apply.
