Hello you,
i have tried to figure out a way to equip my Beryl AC1300 with LTE connectivity.
I found the following in the docs: Cellular - GL.iNet Router Docs 4
And decided to buy the one modem i could find online, the Quectel EM060K-GL.
Amazon-Link: Amazon.de
I put the modem into a carier board from Waveshare: https://amzn.eu/d/cR5BWj7
The lights are activated and if i plug the carier board into my PC it shows up and i immediatly have LTE connectivity.
Unfortunately this isn´t the case for my Beryl AC1300.
If i plug the carier board into the router it doesnt detect it:
And running dmesg in the console, throws the following:
I stumbeled upon some posts which had a similar or identical problem, but i can´t figure out what to do.
Posts i found:
I would really appreciate if someone has a fix or an idea i could test out.
Thank you in advance ![]()
