I have an X3000 using a T-Mobile SIM on the latest stable firmware 4.4.9. I am having issues with poor speeds on 5G with full signal strength, about 5 down / 3 up. Am also getting regular packet loss every 10–15 seconds.
The cellular on it doesn't like to connect automatically, I often need to reboot it or click manual setup once or twice to make it fully connect. I've been having these issues since I bought it across multiple firmware versions.
To troubleshoot, I am trying to update the Quectel modem firmware using SSH, but QFirehose fails with Quectel module not found no matter what I do.
gl_modem AT AT+QGMR just returns Modem is not exit.Please make sure bus.
Is my unit just defective?
BusyBox v1.33.2 (2024-06-15 05:17:39 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 21.02-SNAPSHOT, r15812+880-46b6ee7ffc
root@X3000:~# gl_modem AT AT+QGMR
root@X3000:~# cd /usr/bin/ && wget https://fw.gl-inet.com/tools/quectel_tool/QFirehose-mtk7981a-sha256-c0b944
Downloading 'https://fw.gl-inet.com/tools/quectel_tool/QFirehose-mtk7981a-sha256-c0b944'
Connecting to 99.84.66.5:443
Writing to 'QFirehose-mtk7981a-sha256-c0b944'
QFirehose-mtk7981a-s 100% |*******************************| 106k 0:00:00 ETA
Download completed (109208 bytes)
root@X3000:/usr/bin# chmod 775 QFirehose-mtk7981a-sha256-c0b944 && sha256sum QFirehose-mtk7981a-sha256-c0b944
c0b944f62e5ef9e83a71775b494f96d661b0ffafa3490ddb901e460084cd0ffb QFirehose-mtk7981a-sha256-c0b944
root@X3000:/usr/bin# wget http://192.168.8.134:1180/RM520NGLAAR01A08M4G_2024_04_03.zip -P /
Downloading 'http://192.168.8.134:1180/RM520NGLAAR01A08M4G_2024_04_03.zip'
Connecting to 192.168.8.134:1180
Writing to 'RM520NGLAAR01A08M4G_2024_04_03.zip'
RM520NGLAAR01A08M4G_ 100% |*******************************| 132M 0:00:00 ETA
Download completed (139002193 bytes)
root@X3000:/usr/bin# ls /
RM520NGLAAR01A08M4G_2024_04_03.zip lib64 sbin
bin mnt sys
dev overlay tmp
etc proc usr
init rom var
lib root www
root@X3000:/usr/bin# unzip /RM520NGLAAR01A08M4G_2024_04_03.zip -d /RM520NGLAAR01A08M4G_2024_04_03
Archive: /RM520NGLAAR01A08M4G_2024_04_03.zip
inflating: /RM520NGLAAR01A08M4G_2024_04_03/contents.xml
inflating: /RM520NGLAAR01A08M4G_2024_04_03/md5.txt
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-recoveryfs.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/multi_image_qti.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/uefi.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/oemdata.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/multi_image.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl_config.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/abl.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/logfs_ufs_8mb.bin
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/devcfg.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/devcfg_low_ddr.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/hyp.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/ipa_fws.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-sysfs.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/usrdata.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/NON-HLOS.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/tz.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-boot.img
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/aop.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/oemapp.ubi
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/apdp.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/partition_nand.xml
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/partition.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl_ramdump.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/patch_p4K_b256K.xml
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/rawprogram_nand_p4K_b256K_update.xml
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/partition_complete_p4K_b256K.mbn
inflating: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/prog_firehose_lite.elf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/Quectel_RM520N-GL-AA_Firmware_Release_Notes_V0108_01.203.01.203.pdf
inflating: /RM520NGLAAR01A08M4G_2024_04_03/Quectel_RM520N-GL-AA_????????????????????????_V0108_01.203.01.203.pdf
root@X3000:/usr/bin# QFirehose-mtk7981a-sha256-c0b944 -f /RM520NGLAAR01A08M4G_2024_04_03
[000.000]: Version: QFirehose_Linux_Android_V1.4.13
[000.000]: Builded: Apr 12 2023 03:15:42
[000.000]: Find md5 check file </RM520NGLAAR01A08M4G_2024_04_03/md5.txt>
[000.001]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/contents.xml pass
[000.003]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/abl.elf pass
[000.005]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/aop.mbn pass
[000.005]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/apdp.mbn pass
[000.006]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/devcfg_low_ddr.mbn pass
[000.007]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/devcfg.mbn pass
[000.007]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/partition_complete_p4K_b256K.mbn pass
[000.007]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/patch_p4K_b256K.xml pass
[000.014]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/prog_firehose_lite.elf pass
[000.015]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/firehose/rawprogram_nand_p4K_b256K_update.xml pass
[000.016]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/hyp.mbn pass
[000.017]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/ipa_fws.elf pass
[000.017]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/logfs_ufs_8mb.bin pass
[000.017]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/multi_image.mbn pass
[000.018]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/multi_image_qti.mbn pass
[000.817]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/NON-HLOS.ubi pass
[000.825]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/oemapp.ubi pass
[000.831]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/oemdata.ubi pass
[000.831]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/partition.mbn pass
[000.832]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/partition_nand.xml pass
[000.922]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-boot.img pass
[001.090]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-recoveryfs.ubi pass
[001.792]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/sdxlemur-sysfs.ubi pass
[001.803]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/tz.mbn pass
[001.824]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/uefi.elf pass
[001.867]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/usrdata.ubi pass
[001.868]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl_config.elf pass
[001.875]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl.elf pass
[001.877]: md5 checking: /RM520NGLAAR01A08M4G_2024_04_03/update/xbl_ramdump.elf pass
[001.877]: Totals checking 29 files md5 value, 0 file fail!
[001.877]: find 'prog_firehose_lite.elf'
[001.878]: find_firehose_mbn prog_firehose_lite.elf
[001.878]: Quectel module not found
[001.878]: gl-sdk4-modem-git-2023.110.43692-2ab241c/quec_UPGRADE/qfirehose.c main 354 fail
root@X3000:/usr/bin# gl_modem AT AT+QGMR
root@X3000:/usr/bin# echo 1 > /sys/devices/platform/11280000.pcie/pci0001:00/0001:00:00.0/0001:01:00.0/remove
root@X3000:/usr/bin# echo 1 > /sys/devices/platform/11280000.pcie/pci0001:00/0001:00:00.0/rescan
