Quectel Module Testing (EU + Global Modules)
The following tests were done at the same locations with 2 different modules inside the Mudi, EC25-E and EP06-E. For all tests the Mudi was in my jacket pocket at around hip height. No metal was near the Mudi to affect reception. The Mudi was also using the default settings. I only set the password on initial install, nothing more. My Huawei Mate 20 Pro was connected to the 5ghz wifi of the Mudi for the tests.
EDIT: Added GLOBAL module to the tests bellow (Quectel EG25-G)
Operator: Tele2 / Comviq
Suburbs
EG25-G
Imgur
EP06-E
Imgur
Peak
EG25-G
Imgur
EP06-E
Imgur
Park
EG25-G
Imgur
EP06-E
Imgur
City
EG25-G
Imgur
EP06-E
Imgur
Operator: Telia
Suburbs
EC25-E
Imgur
EG25-G
Imgur
EP06-E
Imgur
Peak
EC25-E
Imgur
EG25-G
Imgur
EP06-E
Imgur
Park
EC25-E
Imgur
EG25-G
Imgur
EP06-E
Imgur
City
EC25-E
Imgur
EG25-G
Imgur
EP06-E
Imgur
Results
The EP06 CAT6 module is more stable overall with less dropped packets and was consistently faster than the CAT4 modules. For Telia it was rated limited to 50mbit for some reason, but that is just my subscription i guess. My recommendation is you get the CAT6 modules and swap them if you need to go from one region to the next.
The EG25-G global module is more convenient, but you loose the stability. It might just require a firmware update, but at this moment the CAT6 modules are still faster and more stable.
Hi, sorry for bumping this topic
since 5G is coming to my country, is there any possibility for changing mudi module to 5G module (quectel or any other type module)?
or maybe is there any information gl-inet will launch 5G router?
Thanks
Regards
Sorry we do not have 5G router now. Don’t have an update yet.
