1.Why there are 2 GL-Inet apps in the Apple App Store.
2. What has happened to the one that has a green icon, it can’t connect to my AR750S?
Thank you.
Thank you.
The new one (blue one) supports the new B2200 Velica and will support previous models only if they are running snapshot 3.201 firmware.
It’s a lot more functional than the old Green app!
If you are using AR750S, it already has firmware 3.201, please upgrade and use the new app.
https://docs.gl-inet.com/en/3/release_notes/
iOS: glinet on the App Store
Android: https://play.google.com/store/apps/details?id=xyz.goodcloud.glinet
Beta version:
iOS TestFlight: Join the glinet beta - TestFlight - Apple
Google Play Beta: https://play.google.com/apps/testing/xyz.goodcloud.glinet
