I have some questions about the EFR32 module that come with the GL-AP1300 and GL-S1300.
Out of the box, the module is configured for BLE. Would you be able to provide the Zigbee (EZSP) firmware for this module?
I assume module is programmable via the debug pins labelled in the datasheet. Is this the case?
The S1300 comes with 2 separate stamp headers (BLE/UART and Zigbee/SPI). Is the EZSP firmware therefore SPI-only, and does the module have to be moved to the SPI header after reprogramming to Zigbee?
The AP1300 only has one stamp header. Is this header capable of both UART and SPI?
Would it be possible to have pinouts for these stamp headers?
Can you provide the Zigbee firmware? I am able to remove the module and flash manually if this is necessary; If you could provide instructions that would be useful.
