Quickly check if your KVM is under attack
UPDATE (from @AdamK): Please use this diagnostic tool to do a thorough scan if your KVM is affected and follow the guidance.
Step1: Access the KVM Terminal.
Step2: Execute quick check command
If the model is RMQ1, please execute
ps -a| grep tmp
for other models, please execute
ps -aux| grep tmp
If the output contains crond -i /tmp/.log, the device is under attack.
If there is no output or the output is otherwise displayed, it means your device is secure and you can still use it with confidence, as external attack paths have been completely blocked.
If the device is found to be under attack, you can choose to upgrade to the latest firmware or reset the device.
Latest firmware download:
RM10 (1.10.2 beta or later)
RM10RC (1.10.2 beta or later)
RM1 (1.10.2 beta or later)
RM1V2 (1.10.2 beta or later)
RMQ1 (1.8.6 beta or later)
RM1PE (1.10.2 beta or later)
RM4PE (1.10.2 beta or later)
Do 1.11.0 releases include the security fix? Eg V1.11.0 beta3
1.11.0 is pushed to rm10 devices with beta updates enabled.
If your self-check confirms that your device has been attacked, please use the beta firmware in my link first. If your device is healthy, no firmware upgrade is needed.
For what it's worth, I would recommend not selecting "Keep saved configuration" when upgrading a device that has tested positive for compromise, since preserving the configuration could also preserve malicious files or persistence mechanisms.
I upgraded my infected GL-RM10 to the new V1.10.2 beta without keeping the configuration. The four previously detected gl-helper malware files and the suspicious rc.local entry are now gone.
However, I initially lost remote access to the device. After troubleshooting through a Raspberry Pi on the same LAN, I discovered a Tailscale subnet-routing conflict that was preventing local connections. The RM10 itself was reachable and its web interface was functioning.
I was able to regain access through an SSH tunnel, but the RM10 still appears offline in the GLKVM cloud portal. The logs show that the MQTT connection is accepted, but the cloud agent reports Token Invalid and bind:false.
Is this expected behavior after upgrading without preserving the configuration? Does the device need to be rebound to the GLKVM account, or is there another procedure to restore cloud access remotely?
If you find your KVM has been attacked, and it was attached to any sensitive system - such as a corporate laptop with a logged-in session - then turn your KVM OFF and preserve it for evidence. If this device was used to parlay a breach into a corporate system, this KVM will be the only evidence to demonstrate it was not YOU personally, and potentially keep you out of jail.
This is not a joke or hypothetical. You do not destroy infected device evidence until you have the full context.
@robotluo - that is extremely reckless guidance to anyone in the USA (and I suspect EU).
Can you please be more clear?
What is a suspicious content on the rc.local?
Worth to inform what is the default content of the original rc.local
On my MT3000, the Community Fix script says it was changed and the content is:
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
. /lib/functions/gl_util.sh
remount_ubifs
exit 0
