Random Mac Update Error MT-3000 Beryl
I updated wan to random mac address. There was an error. I don't have a screenshot. Now, I can't access the router admin at all. I can see the light flashing. I tried to reset and uboot, but nothing works.
I can't reset or uboot. I even used a different gl inet router. Still can't access admin, 192.168.8.1. I guess something is blocking it.
Is the LED on your Beryl AX (GL-MT3000) flashing blue slowly? If so, the system has booted correctly and is operating normally. If you still cannot access the interface, please refer to our troubleshooting guide to rule out IP address or browser configuration issues:
If the issue persists, please try again to restore the device using one of the following methods:
  1. Factory Reset: Follow the Repair or Reset Guide to clear all settings.
  2. U-Boot Recovery: If the reset fails, you can reflash the firmware through the U-Boot Debrick Method.
If none of these steps resolve the problem, please contact our support team at support@gl-inet.com. To help us assist you faster, please include a link to this discussion along with your purchase channel and order number.
Followed Check the general steps to access web Admin Panel. It worked. Thanks
