I have followed the suggested instructions to create the wireguard client for both a raspberry pi wireguard server and a windscribe wireguard server using the administrator panel :
The windscribe one works flawlessly while the raspberry pi one does not connect. For the latter I get an orange light instead of a green light when I try to connect
I attach the relevant screenshot from the administrator panel, where you will see that all fields are duly completed.
My questions are: 1. do you see anything wrong, and second, i read in some forums that it is necessary to change the firewall settings, is this necessary or the set up through the administrator panel is sufficient as it has been for my windscribe client?
