Can we really not communicate with devices on 2 different routers?
My need:
My master router is a D-link tri-band and AR300M is connected with cable connection in DHCP mode.
I use a desktop at home which connects to an AP on the D-link router.
I have another laptop which connects to the AR300M AP.
I want to be able to RDP from my desktop to my laptop while they are connected to different AP’s.
It should be possible if the AR300M has an IP from the master router. Maybe some port forwarding from Luci?
Why not use bridge mode on the AR300M? You can set bridge mode in the UI if you use firmware v2.261.
If you don’t want to use bridge mode, surely you can set up port forwarding etc but have to understand how RDP work. You need to know the port RDP is using.
