RE: AX-3000 Spitz Profiles
I am confused at the purpose of Profiles in the AX-3000 Admin Panel. What is the significance to 'adding" a profile to the list? There doesn't appear to be any way to assign a profile to a SIM card so why put one in the list?
What is your firmware version?
It should be able to assign.
After you created a profile from "manage profiles" option, you can simply assign a profile to a SIM card just selecting "manual setup" and then clicking on "Select a profile".
Excellent. Thanks for explaining that.
