Using the MT3000 Beryl AX, in repeater mode, and I accidentally switched off my main wireless network..
Sadly, I don't have a ethernet port available.
Im aware I can reset the router, but i want to avoid that, and see if i can fix this without it. Partially just cause it's interesting.
The guest networks are up, but it seems that they are blocked from reaching the admin interface.
I was wondering if I can use the USB port somehow to get in. That any possible?
There's also another router with me, and i've tried putting it on the lan, but i still cannot reach it, which makes sense, but maybe there's a way to make a route to it?
The two aren't on the same subnet. [i think..?]
The GL is 192.168.8.1, and the other is one is 192.168.68.0, which in turn connects to another one which is 192.168.1.0
So just like that they should be stranger, right?
Unless you configure them to know they aren't?
