Hi all,
i have a question. i would like to know if GL-XE300 can reply a sms if i send to it an AT- command by my phone.
E.g
"if i send the sms with this AT command AT&F0 by phone, the modem reply to me and reset the modem".
Thank you
Hi all,
E.g
Thank you
Hi, it does not support.
Ok, thank you for reply. I have asked it because often the modem of the router, doesn't work and we cannot reach it by cloud or SSH. The modem works again if somebody reboot the router. When we are near to router, we noted that wifi works and also the router, only the 4G modem doesn't work. It is a problem for us because the router are in different city, many of them are very very far to us.
Is there a solution?
