config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix ‘fd1e:fd4d:cd9c::/48’
config interface ‘lan’
option type ‘bridge’
option ifname ‘eth0.1’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-AR750S-6b6’
option ipaddr ‘192.168.8.1’
config interface ‘wan’
option ifname ‘eth0.2’
option proto ‘dhcp’
config interface ‘wan6’
option proto ‘dhcpv6’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
config switch_vlan
option device ‘switch0’
option vlan ‘1’
option ports ‘2 3 0t’
config switch_vlan
option vlan ‘2’
option ports ‘1 0t’
config interface ‘wwan’
option proto ‘dhcp’
option metric ‘20’
root@GL-AR750S:~# cat /etc/config/wireless
config wifi-device ‘radio0’
option type ‘mac80211’
option channel ‘36’
option hwmode ‘11a’
option path ‘pci0000:00/0000:00:00.0’
option htmode ‘VHT80’
option doth ‘0’
option txpower ‘20’
option band ‘5G’
option disabled ‘0’
config wifi-iface ‘default_radio0’
option device ‘radio0’
option network ‘lan’
option mode ‘ap’
option encryption ‘psk-mixed’
option ifname ‘wlan0’
option wds ‘1’
option ssid ‘OATMEAL’
option key ‘1234abcd’
config wifi-device ‘radio1’
option hwmode ‘11g’
option path ‘platform/qca956x_wmac’
option txpower ‘20’
option noscan ‘1’
option htmode ‘HT40’
option band ‘2G’
option disabled ‘0’
option channel ‘1’
config wifi-iface ‘default_radio1’
option device ‘radio1’
option mode ‘ap’
option ssid ‘GL-AR750S-6b6’
option wds ‘1’
option ifname ‘wlan1’
config wifi-iface ‘sta’
option network ‘wwan’
option mode ‘sta’
option ifname ‘wlan-sta’
option ssid ‘Parkplace’
option channel ‘1’
option bssid ‘E4:BE:ED:8D:B2:9E’
option encryption ‘none’
option disabled ‘0’
root@GL-AR750S:~#
