I was building a new version of openwrt for the MT300N devices that we use and messed the build up, locking myself out of the device somehow. I suspect a network config error. Typically, I put those aside, fix the problems and move on to the next device. I wanted to see just how hard they would be to recover and tried all of the variations I could find in terms of resetting it but nothing works.
Now I want to see if I could recover it since it has serial pins already installed. I have a USB/TTL cable installed on a win7 PC and connected to the device. Tx/Rx/Gnd, 115200, 8N1. Again, nothing. Not even garbage on the screen.
Two LEDs come on when starting the device, then one remains on for good. No other changes no matter what I try.
If I can recover this device, I will see if we can start using it as our default one since 1GB NICs are coming.
At some point, we’ll want a custom version of the whole thing but right now, orders would be based on how many any one customer wants. 1, 5, 100, 500, etc. Most will only want one or a few at a time.
If the device still power on (led light up), it should still be live.
One question, the green wire (tx on MT300N) should connect to the RX of your adapter, right? Sounds stupid but it must be made sure.
Second question, when you use a serial term and connected to the USB uart adapter, when you type in the term windows, did you see the USB uart adapter has some LED flashing? Generally when data is transferred, the adapter has an LED indicating the data. This is to make sure your adapter has good connection with your computer.
Green is Tx on the adapter and is connected to Tx on the MT300N. I’ve tried reversing the Tx and Rx. I should at least be able to get garbage but get nothing what so ever.
Strange, it worked in reverse as you said. It just took several minutes to show anything in the terminal.
Now I need to figure out how to login to the device in order to make the changes. It seems the network is messed up and ssh is disabled.
Seeing ARP request weirdness.
Loading: [08]T T T T T T T T T T
Retry count exceeded; starting again
ArpTimeoutCheck
TFTP from server 192.168.1.2; our IP address is 192.168.1.1
TIMEOUT_COUNT=10
Loading: [08]T T T T T Got ARP REQUEST, return our IP
T checksum bad
checksum bad
checksum bad
T T T
ArpTimeoutCheck
TIMEOUT_COUNT=10
