I would like to redirect some domains to better privacy copies of those domains, but I want to keep the payload.
I have a GL.iNet Flint 2 router with Adguard home set-up.
For example, I would like to redirect: example.org/test to google.com/test
Is this possible? thanks
No, this isn’t possible - at least not without having some proxy. You can’t redirect URLs, only domains with AdGuard - and it will destroy the payload most likely. (Since it’s not a real redirect but just another IP as response)
Thank you for your quick response.
