Hi Everyone,
We have 11 pcs refurbished AR150 routers for sale at White (GL-AR150) Mini Smart Router | Pocket-sized | VPN | Travel-friendly — GL.iNet.
You can order directly if you are interested in.
Note: The Refurbished AR150 does not come with outer packaging or cabling.
Product Description
• Wireless Mobile Mini Travel Router: 40g (1.41 Oz) only, travel-sized, and compact design fits in with any pocket.
• Open Source & Programmable: OpenWrt pre-installed, DDWrt supported. USB disk is extendable.
• Large Storage & Extensibility: 64MB RAM, 16MB Flash ROM, dual Ethernet ports, UART, and 2.54mm standard GPIOs for hardware DIY.
• Security & Privacy: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers.
• PoE Power Supply (Optional): You can only use one power supply method at one time, either via PoE (Power over Ethernet) or micro USB cable. The PoE injector should be compatible with active or passive 48V 802.3af standard. PoE only works on the WAN port.
