Are there any.
Is there anything specific/new to test.
Cheers.
Are there any.
Cheers.
That was where I found the firmware, that prompted my questions.
But there are no Release Notes.
Cheers.
At least the “Toggle Button Settings” is back ! ![]()
It it’s just me or the menus “text” it’s mess up everywhere?
I think I know what you are seeing!
To fix it set your UI language again then the placeholder tags are gone, though I think this needs to be reported as bug to, could you screenshot it?
Oh my bad, I forgot to report back, it got fixed by itself with a hard reboot, it’s all good now
with the new update i have often this kind of disconection when using as repeater
Blockquote
Thu Jun 2 09:05:18 2022 daemon.notice netifd: wwan (6552): udhcpc: lease of 192.168.1.242 obtained, lease time 3600
Thu Jun 2 09:33:13 2022 daemon.info dnsmasq-dhcp[769]: DHCPREQUEST(br-lan) 192.168.8.244 f0:2f:4b:13:8b:06
Thu Jun 2 09:33:13 2022 daemon.info dnsmasq-dhcp[769]: DHCPACK(br-lan) 192.168.8.244 f0:2f:4b:13:8b:06 emm16MBP
Thu Jun 2 09:35:17 2022 daemon.notice netifd: wwan (6552): udhcpc: sending renew to 192.168.1.1
Thu Jun 2 09:35:17 2022 daemon.notice netifd: wwan (6552): udhcpc: lease of 192.168.1.242 obtained, lease time 3600
Thu Jun 2 10:05:17 2022 daemon.notice netifd: wwan (6552): udhcpc: sending renew to 192.168.1.1
Thu Jun 2 10:05:17 2022 daemon.notice netifd: wwan (6552): udhcpc: lease of 192.168.1.242 obtained, lease time 3600
Thu Jun 2 10:15:09 2022 daemon.info dnsmasq-dhcp[769]: DHCPREQUEST(br-lan) 192.168.8.126 7a:2d:75:b9:ca:9d
Thu Jun 2 10:15:09 2022 daemon.info dnsmasq-dhcp[769]: DHCPACK(br-lan) 192.168.8.126 7a:2d:75:b9:ca:9d
Thu Jun 2 10:35:17 2022 daemon.notice netifd: wwan (6552): udhcpc: sending renew to 192.168.1.1
Thu Jun 2 10:35:17 2022 daemon.notice netifd: wwan (6552): udhcpc: lease of 192.168.1.242 obtained, lease time 3600
Thu Jun 2 10:35:49 2022 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED f0:2f:4b:13:8b:06 0 0
Thu Jun 2 10:35:50 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 IEEE 802.11: disassociated
Thu Jun 2 10:35:51 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Thu Jun 2 10:35:58 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 IEEE 802.11: authenticated
Thu Jun 2 10:35:58 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 IEEE 802.11: associated (aid 1)
Thu Jun 2 10:35:58 2022 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED f0:2f:4b:13:8b:06 0 0
Thu Jun 2 10:35:58 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 RADIUS: starting accounting session 3868D55EE25F78C1
Thu Jun 2 10:35:58 2022 daemon.info hostapd: wlan0-1: STA f0:2f:4b:13:8b:06 WPA: pairwise key handshake completed (RSN)
Thu Jun 2 10:35:58 2022 daemon.info dnsmasq-dhcp[769]: DHCPREQUEST(br-lan) 192.168.8.244 f0:2f:4b:13:8b:06
Thu Jun 2 10:35:58 2022 daemon.info dnsmasq-dhcp[769]: DHCPACK(br-lan) 192.168.8.244 f0:2f:4b:13:8b:06 emm16MBP
Thu Jun 2 10:43:27 2022 user.info : luci: accepted login on / for root from 192.168.8.244
Sometimes it can just be cached from the previous firmware version. For good housekeeping consider to empty cached content from the browser, when the issue is UI rendering.
also available for flint, yummy
yes it’s that but also and buggy. ![]()
I am seeing bugs on the AX1800 version that I don’t see on the AXT1800
