I’d like to know if anyone has a good reference for me to learn how to use the GL-AR150 as a device (ethernet-)connected to my router at home, so that it creates a VPN server to allow me to access my network remotely.
That is, I want to access my home network from work, for example, through a VPN. I want to make sure I don’t need a (paid) VPN provider. I just want to leave the GL-AR150 continuously connected.
Hey @alzhao, thanks for the quick reply.
Do you know anywhere I can read more about how to set up port forwarding for this specific implementation? I am a bit new to VPN and router configuration.
Thanks again,
Thanks @Johnex. I think the VPN server configuration I can handle.
My only concern is understanding port forwarding. Is this only an enabled/disabled kind of configuration, or I’ll actually need to check on the GL-AR150 for some parameter and match it in the port forwarding settings of the router?
The “portfoward.com” link you’ve sent indeed has a page for my router, but it’s only a screenshot. From what I gather, I’ll need to check the IP address of GL-AR150 and just enable port forwarding for this IP in the router page. Is this correct?
Thanks again,
You don’t need to do any port forwarding on your AR150, just the main router.
The OpenVPN default port is UDP 1194. So you want to add a new rule in your main router that will open port 1194 and route it to the IP of the AR150 and port 1194. You can also add a static IP to the AR150 in your main router if you wish. That will prevent the IP of the AR150 from changing in the future.
Hmmm… That’s good, now I understand a bit better what @alzhao meant when mentioning port 111 for the router and port 111 again later. This means the list of actions I must do are:
on the router: set static IP for AR150
on the router: open port 1194 and direct it to the static IP I defined
on AR150: configure OpenVPN and save config file to use in my computers.
Yup that is all you need to do
If your router allows setting the port forward protocol, ie TCP, UDP or Both, keep that in mind when setting up the OpenVPN configuration, as you can use TCP or UDP and both configurations must match on that too.
Perfect! Thanks a lot for the help! I’ve been reading on this all Sunday to no avail! Hehehe…
I’ll try to do it this weekend, if I need anymore help I’ll come back!
Many thanks, again!
One last thing. Nowadays OpenVPN is quite old and clunky, I would recommend a new Wireguard configuration instead. There are clients for all the platforms, or you can use a second GL router as client. The configuration would be the same for wireguard, with the port forwarding requirement. Read up on that, since you will get much higher performance out of the AR150 with Wireguard vs OpenVPN.
Oh, good to know! But I thought that the AR150 couldn’t use WireGuard because it requires a 3.xxx firmware…
If I’m mistaken and I actually have access to it, I’ll try to set up WireGuard instead.
Hey everyone, thanks again for the help before (specially @Johnex), everything worked just fine!
I have an additional question regarding the VPN Server.
I am able to access my home network and control my routers through the VPN.
However, I am unable to print through the VPN.
Any ideas?
