I want to access the admin panel of the router remotely through a WG connection ( from the WG server side) . I setup the router as a WG client and the tunnel works fine my home clients behind the router pass through the tunnel.
However I cannot at all ping the Wireguard IP address of the router, nor ssh to it. I guess it must be related to the firewall but I don’t understand how GLiNet firmware handles wireguard. I see a wireguard zone but no wireguard interface.
Any idea how can I access the router admin interface through WG from the server side ?
In the wireguard connection, there should be an option “allow local access”. When you select you should be able to access the router using the wireguard IP.
Just use zerotier installvit on your router and phones and pc all connected 24/7 no need for a vpn its like having a virtual eathernet cord plugged into your phone no matter where you go even does udp hole punching.
