Does anyone have any tips on running Remote.It “Jump” service on a GL-ARM300M. Remote.It website only has setup details for Raspberry Pi.
Since I never heard of this, I can only tell you that there is an OpenWrt package:
https://downloads.remote.it/remoteit/v4.20.1/remoteit_4.20.1.ipk
opkg install remoteit_4.20.1.ipk
should work then.
This file did work, Thank you. I did however, eventually find it in under “Plug-in’s” tab with-in routers setup GUI.
