Hi there, looking for understand if it is possible an SSH to the remote (second) Mango I’m connected in site to site setting from a lan under the local (first) Mango. In other words, from my PC under the first Mango LAN I have access to all the settings of the remote (second) Mango, but when I try with putty an SSH to have access to the router: connection refused !
Tried all settings I think are appropriate, but still connection refused. May anyone help me ?
- If your network typology is like above, it should work that SSH from PC to Second Mango by default setting.
- What is your each Mangos’ firmware version?
- You can try the RTTY Cloud - GL.iNet Docs
Hi Leo, thanks for your reply. Yes, the SSH works as expected. Yesterday have flagged the post to submit to the mod for remove my post, since I found it was memorized a wrong IP, and I was repeatedly making the same mistake.
