Remove PIN code entirely
Is there a way to remove the PIN CODE entirely.
The sim is a different format than my phone.
I do not have access to an old phone
Can I do this with ssh command line ? or in the control panel somehow ?
I have Gl-X750
I have no idea if this can be done on the router.
The router can input pin. If you can use why should you remove the pin?
found this; looks like it works
https://mulaz.org/me/2017/03/16/removing-sim-pin-using-at-commands/
So have you tried in X750 with these commands?
#verify pin is enabled:
AT+CPIN?
 +CPIN: SIM PIN
#disable pin:
AT+CLCK="SC",0,"<PIN>"
 OK
#(eg: AT+CLCK="SC",0,"1234")
#verify:
AT+CPIN?
 +CPIN: READY
Yes i did. Got a success message fir the disable line but had to use usb2
