Removing Astrorelay config from Router
Hi there,
I set up Astrorelay in my GL-MV1000 router in order to configure a Wireguard VPN in a not public IP address scenario (ISP blocks by some reason).
The configuration script executed fine, and the Wireguard VPN is working perfect.
My question is: if one day I opt by stop using Astrorelay, how do I revert the config that was done?
Is there another script to remove Astrorelay? Are there some packages that I need to remove?
Regards,
A factory reset should clear out AstroRelay and an other related changes.
