Hi everyone. Really silly and basic question, I might be wrong, but I’m sure I have renamed devices before. I am running a Flint router and I’m looking to name all the devices connected. I have a few that seem to have auto named and a few static that Havnt that I would like to name, IE, Nvidia Shield, Formuler Z10 then to name all our individual mobiles and tablets. I have tried through the web UI and also the mobile app and I can’t for the life of me figure it out.
Ok thanks, I’ve tried restarting the Flint, I’ll try pulling the plug out and reconnecting.
Another strange one, I have a Netgear switch connected to the Flint yet I can’t find my Shields IP address, Shield is hard wired to the switch, in turn hard wired to the Flint. I want to set the Shield to go via vpn but not other devices like the kids iPads and the PS5 etc, again Shield has a static IP (I try to static IP my items so I can control them but keep smaller things like kids stuff, Alexa etc all just set as DHCP on the 2.4).
I’ve had the router since release but have only been using as a repeater. Only started it as the main router yesterday.
Forget about the shield, as I had it set as a static IP it still had the old hubs gateway (192.168.1.254 and Flint is 1.1) changed and now visible. Was throwing me as still had internet access.
In order for hostnames of connected devices to display consistently, the client devices have to be assigned static IP addresses from the router because each hostname is associated to a unique IP address and non-static IP addresses may change over time. You can set up static IP address assignments to their MAC addresses via LuCI → Network → DHCP and DNS → Static Leases. There should not much propagation time because the mappings are all on the router itself and do not get propagated out on the Internet.
For client devices with static IP addresses manually configured on the devices themselves, you still have to add them to the router, or else the router may not know about them. Note that some makes/models of devices automatically send out their factory or user-defined hostname via Option 12 of the DHCP protocol, but the factory hostnames are generic and you may want to set them yourself.
I suggest assigning static IP addresses to MAC addresses for all your devices that you want displayed, which is what I do, even if the client device has a static IP address manually configured on it…
EDIT:
Client devices with static IP addresses manually configured on the devices themselves may not be able to display their hostnames because they never get an IP address from the DHCP server, even if they have been assigned static IP addresses to MAC addresses in the router’s DHCP server.
If I rename via Luci, then should the rename work via the normal login/ app? I seem to have to use a mix of all 3, my strong VPN can only be setup via the app (login not adding manually).
Then I mostly use the normal log in then Luci when needed. This is the normal login.
3 of these devices have been renamed via Luci.
Still show as a * in normal web gui.
See wcs2228’s post above re static IP at device level and firstly try changing your devices to DHCP then use Static Lease instead of Hostnames to name and static Ip your devices.
(or try one first and see what results)
