i was trying to solve a minor issue and ran some updates on packages and broke nginx. when i check the logs nginx is failing to parse the lua directives
can i please have some help reinstalling the library nginx uses to run lua?
Maybe just replaced the nginx config.
Can you check if there is /etc/nginx/nginx.conf_old which is the backup of the original config.
Thanks i just factory reset and backed up my custom config
