Repeated Goodcloud Failures
Over the past week or so, I’ve been observing repeated goodcloud.xyz failures in my logs.
Examples appear as:
2026-04-29 00:10:16 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:10:16 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:10:16 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:10:16 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:10:17 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:10:17 JaLoJaSh gl-cloud[20491]: (gl-cloud:992) connect mqtt broker: 18.209.114.161 28883
2026-04-29 00:10:17 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:10:17 JaLoJaSh gl-cloud[20491]: (gl-cloud:1182) conack: 0 connection accepted
2026-04-29 00:19:17 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:19:17 JaLoJaSh gl-cloud[20491]: (gl-cloud:1244) error: Connection reset by peer
2026-04-29 00:19:17 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:19:17 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 5s...
2026-04-29 00:19:22 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:19:22 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:19:23 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:19:23 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:19:24 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:19:24 JaLoJaSh gl-cloud[20491]: (gl-cloud:992) connect mqtt broker: 18.209.114.161 28883
2026-04-29 00:19:24 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:19:24 JaLoJaSh gl-cloud[20491]: (gl-cloud:1182) conack: 0 connection accepted
2026-04-29 00:27:24 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:27:24 JaLoJaSh gl-cloud[20491]: (gl-cloud:1244) error: Connection reset by peer
2026-04-29 00:27:24 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:27:24 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 5s...
2026-04-29 00:27:29 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:27:29 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:27:30 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:27:30 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:27:31 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:27:31 JaLoJaSh gl-cloud[20491]: (gl-cloud:992) connect mqtt broker: 18.209.114.161 28883
2026-04-29 00:27:31 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:27:31 JaLoJaSh gl-cloud[20491]: (gl-cloud:1182) conack: 0 connection accepted
2026-04-29 00:53:31 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:31 JaLoJaSh gl-cloud[20491]: (gl-cloud:1244) error: Connection reset by peer
2026-04-29 00:53:31 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:31 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 5s...
2026-04-29 00:53:36 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:36 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:53:37 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:37 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:53:38 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:38 JaLoJaSh gl-cloud[20491]: (gl-cloud:933) fetch server fail:-6 Too many requests. Please try again later.
2026-04-29 00:53:38 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:38 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 10s...
2026-04-29 00:53:48 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:48 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:53:48 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:48 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:53:49 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:49 JaLoJaSh gl-cloud[20491]: (gl-cloud:992) connect mqtt broker: 18.209.114.161 28883
2026-04-29 00:53:49 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:49 JaLoJaSh gl-cloud[20491]: (gl-cloud:1182) conack: 0 connection accepted
2026-04-29 00:53:49 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:49 JaLoJaSh gl-cloud[20491]: (gl-cloud:1244) error: Connection reset by peer
2026-04-29 00:53:49 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:53:49 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 5s...
2026-04-29 00:53:54 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:54 JaLoJaSh gl-cloud[20491]: (gl-cloud:839) fetch ca from: https://gslb-eu.goodcloud.xyz/getCaCert/ca.crt
2026-04-29 00:53:55 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:55 JaLoJaSh gl-cloud[20491]: (gl-cloud:904) fetch server from: https://gslb-eu.goodcloud.xyz/v2/device/auth
2026-04-29 00:53:56 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:55 JaLoJaSh gl-cloud[20491]: (gl-cloud:992) connect mqtt broker: 18.209.114.161 28883
2026-04-29 00:53:56 Daemon.Info 5gGateway.home.jalojash.org Apr 29 00:53:56 JaLoJaSh gl-cloud[20491]: (gl-cloud:1182) conack: 0 connection accepted
2026-04-29 00:55:56 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:55:56 JaLoJaSh gl-cloud[20491]: (gl-cloud:1244) error: Connection reset by peer
2026-04-29 00:55:56 Daemon.Error 5gGateway.home.jalojash.org Apr 29 00:55:56 JaLoJaSh gl-cloud[20491]: (gl-cloud:1296) reconnect mqtt in 5s...
..continuing all day long, every day.
FYI, it turns out that T-MO had made some changes as part of service expansion in my area and had set some controls a bit too strongly.
Luckily, I was able to reach someone higher than 1st-tier support…
Glad you found the issue, good luck.
@wickedyoda me, too. Sadly, they’re still trying to sort this out.
I installed tcpdump on my Spitz and captured the events. It’s definitely some external device sending TCP-RST to my gateway. This has been repeating roughly once a week lately. I guess I’ll have to make another call…
