I'm facing an issue with a GL-SFT1200 (Opal) used as a repeater for a Wi-Fi Network at a campsite, where the repeater function stops working after a while without a clear pattern or trigger.
I'm new in this forum but I've seen already a few posts reporting this exact same problem, although I couldn't find any viable solutions yet.
I post this here to add details about my own setup, hoping this could help to identify possible triggers, solutions or.. workarounds.
The Opal I'm using is currently running version v4.3.18, although I've seen this same issue with previous 4.x versions too (I don't have the exact list, but I have no "working" version to report either):
- everything has been configured exclusively using the GL-iNet UI (I use LuCi only for monitoring)
- The repeater is the only available upstream connection and it uses a WPA2-PSK SSID from the campsite: there are multiple APs deployed at the campsite; roaming seems to happen quite often, as in LuCi I can see that the best RSSI I'm getting in 2.4 is around -73 and the BSSID changes quite often; I'm not sure if the frequent roaming could be related to the issue I'm facing.. I haven't selected the BSSID lock as I noticed that the BSSID with the best signal is not always the same
- I forced the band to be 2.4 GHz on 20 MHz using the GL-iNet UI:
- I have a private SSID, also WPA2-PSK on both 2.4 and 5 GHz, as well as a guest SSID, also active on both bands
- I have configured a Wireguard VPN to my home router, only accessible from the private SSID (I mention Wireguard here as I read another post here where Wireguard was used, although it was configured via LuCI; in my case, the Wireguard VPN was also configured via the GL-iNet UI)
- I have no other plug-ins/packages installed, this is just the basic firmware + the config described above
Based on what I read on other posts, and in order to try to mitigate the issue, I did the following:
disabled the interface status tracking for the repeater; this seems to have mitigated the problem (it still happens, but it seems like since I disabled this check, it hangs once or twice a day, instead of every other hour..):
I configured a scheduled reboot every morning at 5 AM ... but this seems to have no effect, so I'll probably disable this:
So far, I suspect that the upstream network instability may trigger the repeater function to stop working at some point, but I wonder if there could be any solution (e.g., a config to force it to retry connecting irrespective of failures), or workarounds (any script detecting the repeater being disabled and restarting it?!..).
Thanks in advance for any suggestions!
